Question: How hard to change turbo?
Shieldsinc
On a Time Out
Apr 24, 2012
321
Thinkin bout gettin a Danville 66mm stage 2 jw how hard it is the change out being that there's no diesel shops around me.
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
If its anything like an lb7 its a real pita but very doable with limited mechanical experience. Just takes time, patience, and a few makeshift tools.
Shieldsinc
On a Time Out
Apr 24, 2012
321
I'm pretty mechanically inclined just ne'er been that deep in my truck other than transgo jr. In the tranny.
sickdiesel
Apr 22, 2010
1,019
It's really pretty easy if you use the right tools.
If you hook a ratchet strap to the brace under the hood by the fuse box and put the strap around the wrench and use that to break the up-pipe bolts loose it's smooth sailing from there.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Had a thread about turbo removal called"just three bolts" there is everything you need to know in there!
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
It really is pretty simple with the right tools. Just need some long ratchets so you can some ass on the up pipe bolts.:thumb:
