Nozzels are made out of aircraft aluminum, so care must be taken so you dont over speed and heat the drill bit , if you do it will gall the orfice.
so use lube and a bit the size you need, but make sure you have enough material left as not to weaken it an break.
a cloth over the nozzel in a vise with minimal pressure will be fine , just take your time and make sure your straight.
