Make it shift to second really early and downshift really late.
Do you have to adjust the part throttle shifts as well, or just the wot shifts?
Yep, adjust both part and full throttle, and those numbers should work. Just make sure you adjust the downshift as well as the upshift. You don't want to forget that.just to be clear if i put all the speeds to 0 and rpm to 600 this should work?
