Question: how do i get pids onto a V2
663
i know is can be done without v8
i cant figure out how to get it from the pc to the V2.. how do i get from point a to point b? i have tired via 8 but no luck... any one got a step by step how to?
pulled this from here
http://www.duramaxdiesels.com/forum/showpost.php?p=414012&postcount=85
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
In EFI Explorer you want to drag and drop the options.txt file and the file for the particular ECM you are wanting to log
663
where do i find this "options.txt " at?
also what is said file?
all i understand is i pull said pid file that i use when i have 7.5 open logging via the pc.. and that hasnt worked
663
i beliver i found said "options.txt" i can get various pid file names e35a e35b e60 etc pulled up on the V2... when i select said pid file mainle the E35a i get no file or folder found
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
wait are you trying to BBx log? If so you just go into V8, click the BBx box, scan tab, then check your ecm and uncheck the rest, and program.
663
i want to be able to do what i posted up in the first post.. ie fuel, air, as i understand its a live feed.. and much safer looking it while going down the road then trying to look at my screen bouncing on the passenger seat while weaving through truck traffic on a grade.
where is the BBx box at?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
the BBx box is in the left column in the V8 software.
What version of v8 are you using? there should be a slew of .pmm files in that config folder
13,746
821
It is soooo much easier if you just use the Scan and Tune software. Drag and drop. :thumb:
663
got the .pmm file v2 hooked it to the truck, state the EFI_PIDS ECM=MAIN1Q_M was selected and un supported and de-select...
open scan n tune.. deselect said pid.... and find out all pids are metric..... how do i swap to sae?
