I mentioned in another thread that I got what was supposed to be a 2007 Allison with 21K miles on it. Well, I still think it has only 21k miles on it, but when I pulled the output shaft I found the P3 planetary was junk. So, I began tearing into the trans and found a lot more issues. Now, this is the first broken Allison I have been into, but I have seen similar damage to other transmissions that I am familiar with. My thoughts are a loss of lube and ultimately a complete loss of pressure, but I want to see what Mike and the rest of you think.
Here's the C5 clutches. I cannot stress how new these looked (as did the other undamaged clutches), which makes me think this was a 21k mile trans:
Here's the bushing (whats left of it) in the output shaft:
Here's the intermediate shaft:
Here's P3. It looks a lot blacker in person than it does in the pics. One pinion is very crunchy when it turns :
Interestingly, only 2 of the 4 pinions showed signs of damage. Here you can see a "good" one on the left and a fried one on the right:
P2 looked and felt fine. I'm guessing there was no power flowing through it when whatever failed, failed:
The bushing in P2's hub looked hashed though:
P1 has seen better days
C3 got a bit crispy:
Thrust washer showed signs of lube starvation:
C2 was wasted:
Here's the intermediate shaft bushing in the input shaft:
so, what do you think? Lube failure, or something else? I'm thinking it lost a cooler line at speed, and eventually lost enough fluid that holding pressure to the clutches was lost, but I'm not an Allison guru. All I know is that if the seller doesn't make good on it I'm out some money :angry4:
C2 was wasted:
