Does Anyone use this or have any progress with it? I have a sticky injector and having a slight haze at idle and was thinking of giving this stuff a shot, but wanted some feedback from my fellow lb7 lovers!
Putting that in your oil won't help your injector. That is for 95-07 Powerstrokes and other huei systems that use high pressure oil to fire injectors instead of a high pressure fuel pump and common rail system. It's supposed to reduce "stiction" in the oil side of the injector. Your smoke is 99.9% likely from wear and no additives will get rid of it.
