Question: Hot+2 and boost stick??
8lug
Escalade HD
Oct 16, 2009
175
Canada
Hey guys, I notice my Hot+2 clearly adds way more fuel than it efficiently burns. Don't get me wrong the smoke is awesome, however, I was thinking a little more boost might help clear that up a bit and make more power without me having to up it to Lvl 4 (I still haven't installed my lift pump so I get a low rail pressure on 4). My buddy has a boost stick he took out of his truck before he sold it. Would this help or hurt me in any way, he said I could have it for a case of beer. :)
8lug
Escalade HD
Oct 16, 2009
175
Canada
Not 100% sure, just did it and was learning the trans, I doubt I make better than 30PSI.
c2500dmax
God Is Good M.M.
Jun 6, 2010
143
nc
you should get more than 30 when i had my ppe standard on level 4 it was hitting 35psi
8lug
Escalade HD
Oct 16, 2009
175
Canada
This is level 3, I am not sure from a dead stop but I checked today and passing it hits only 28 psi.
graystonelbz
293
Prior Lake,MN
I wouldn't run the boost stick with the PPE tuner.... The boost sticks were used before alot of the tuners added boost( like the predator) If you want more boost lvl 4 has plenty
Colt
Jul 23, 2010
523
I liked the Lev 4 up tunes on PPE because it helped with more boost alot. Seemed to get the best mpg there even driving easy when towing or cruising. Nice tuner with lots of fuel though like he said. Somewhere back here it's said too much boost is a no no... 35 psi is about the best limit for factory turbo or it just makes it too hot after that.
8lug
Escalade HD
Oct 16, 2009
175
Canada
I hear you guys I would love to run level 4 but limp mode every time I pass someone isn't a great option for me, however, if the concensus is to not run the stick, that is what I will do, I will have to wait for the power to come after I get my lift pump bolted up. Thanks for the help guys.
8lug
Escalade HD
Oct 16, 2009
175
Canada
Ya, I'm sure, it's a low fuel rail pressure code. I have turned it down to 3 for the winter. One problem was the petcock on the bottom of the water sensor was dripping, that was definately part of it, but still not enough fuel for level 4.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
PPE adds the correct amount of boost so no need for a boost stick. Also I saw a big improvement when I added my blocker plate when I had PPE. You may already have one in, I dont see it in your sig.
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
i had a boost stick on my lly when stacking ppe hot +2 and the enforcer. Set it for 32lbs boost. It sure smoke like a frieght train
8lug
Escalade HD
Oct 16, 2009
175
Canada
No I don't have a blocker, I am saving up for manifolds and up pipes :)
Colt
Jul 23, 2010
523
PPE says the boost is in their tunes to max. needed per tune.Went back and read early posts for that and boost stick is not needed with PPE tuners. I removed mine after trying it with PPE and it ran better without B stick. Lift Pump fixed the low fuel code and wow the smoke. Now it's EFI and lift pump still holding up good at 15 psi. Just wish I'd got EFI first and been done with the other experimental parts. Stick maker would have to argue the other side if it helps I guess.
Skyhigh4by
Goin to Poochisloose
Apr 13, 2008
408
Powell River, BC
My PPE has been on level 4 for a long time and I've never had any fuel issues. I thought it was more of a problem around level 6. I was also under the impression that tune 4 was pretty close to tune 3 but with added fuel. I think the boost and timing are both pretty high in tune 3. I have spiked about 30 PSI both on level 3 and 4 I dont have a blocker plate or any other mods besides exhaust and k&n cone filter.
8lug
Escalade HD
Oct 16, 2009
175
Canada
That may be true because I can run 3 but 4 throws a low rail pressure code, didn't see anymore boost at that level.
