Okay so over the last few days I've be building my homeade egr delete and y bridge. Few questions...
First, is does anyone know of where to get an aluminum bung for the iat2 sensor? Should be 1.25 pitch 10mm. Next question is related to the fuel block that connects before the cp3, it has a place to pressurize the system. Can I get rid if that? It would work best with my y bridge if I could just use flexible lines instead of the hard metal lines. Plus I think I may have kinked one in the process. Here is the lines so what I'm really asking is do you think the fuel line would hold on to the metal if I cut it shorter and didn't have a groove on the end? It's not high pressure just around 8 psi of so. Other than that I'm almost finished, got my up pipe welded, just waiting on a final 45* tube to arrive later this week
