I am breaking my new motor in with my stock LBZ tune and stock LBZ nozzles. Motor is fresh and I am running twin (new) Industrial 120% over CP3s. Balance rates are all good and motor runs out strong. At idle (800 rpm) I am seeing actual rail pressure much higher than what the tune calls for (60MPa actual vs 38MPa commanded). Once I get off idle the actual and commanded rail pressure are equal and stay dead even from there. Once I let out of the throttle and go back to idle, the rp goes back high again.
I installed a new ATS Twin CP3 controller and the rails, lines, fittings, etc are all like new.
