I have sac 45's and the tunes I'm running from a vendor are commonly around 17-18k psi and around 20kpsi going up any hill, not towing. When I'm towing, its almost all around 20k+ psi...Does that seem high for just regular cruising around? Will this cause premature wear? If so, then i don't see how having sac injectors have a longer life b/c of the higher pressures needed to run them clean.
