LMM: high idle
Nov 4, 2012
182
Harrisonville Mo
I have elevated idle but want my #1 tune to be a high idle like 1000 to 1100 rpms I know a lot of people said it can't be done but if that was the case then how is Kory doing it any input on this would be grate thanks
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
Do u do ur tunes urself? I've done it on lmm's and lbz's its simple. I've never tuned a lb7 to tell you what table to change. On a lbz/lmm it's pedal position or torque based fuel can't remeber. Hope any of that helps.
Dozerboy
4,892
470
TX of course
Their isn't a good way to do it with EFI. Kory is more special then us when it comes to EFI. There are things he can do we can't. With EFI you can just raise the rpms. You don't want your engine going right to 1200rpm when it's cold. Unless your not using it for warm up?
Sent from my iPhone digging a ditch near you.
Nov 4, 2012
182
Harrisonville Mo
Muff I pmd you
Dozerboy I am sure he can do crazy stuff with efi but I don't have a prob with starting my truck on a diff tune and letting it sit for a sec then switching it to high idle thanks for the heads up
