Has anyone done high altitude tuning? Since I live at a low altitude area (1300' above sea level) I basically did my tuning at low altitude and left the medium and high altitude alone. Now I will be going back and forth to Flagstaff from my home, the elevation in Flagstaff is 8k above sea level. I noticed it slowly went back to stock power as I cruised into higher elevation. Can you tune it the same way as low elevation level except for using less fuel but same timing and boost?
I need to know what to avoid in high altitude (medium as well) because I won't be able to hear the engine ping.
My egts were almost similar to my low altitude but the boost are slightly different. The highest it got was 1150* going 75 mph on a grade 7 hill (believe it is a grade 7, it was pretty steep, Brian might know the grade lol).
