LML Hi-Flow or Hi-Capacity DPF?
1,866
Since this is supposed to be a Duramax performance board, what are your opinions on where the aftermarket goes from here now that the EPA has come down against deleting the DPFs/urea on the LMLs?
What would it take to create a DPF that would flow enough or hold enough soot for a hopped-up Dmax, and is any company starting in that direction (other than ATS)? Even though tuners are able to create clean tunes for the LML, what else would have to be done so regen frequency could be kept controlable and reasonable?
Opinions? Thoughts? Ideas?
1,866
I think the problem is more the amount of soot clogging the DPF too quickly, isnt it? So maybe "high-flow" wasnt really what I should say, maybe more like "High capacity"?
Modded the post and title to reflect that.
howie
Dec 26, 2009
167
Sawmills,NC
You could do it the old fashion way and put a whole right down the middle that would help with flow haha
jkholder09
Jan 8, 2012
1,188
Maryland
There is a company we get allot of medium duty truck parts for that cuts them open and cleans rebuilds them, They have allot of different models. I think allot of over the road trucks have really big dpf's. I would think just get one of them, tap in the differential pressure sensors and strap it as close to downpipe as possible so it burns out good.
It would be really nice if someone made one that is easily serviceable.
Like a couple clamps, we pull out a recyclable filter, press a button in cab to tell ecm to check backpressure, it passes regen light goes out, we send filter off or have a place to wash it out etc, and we don't waste diesel cleaning it.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I think the part that is going to hurt is the cost of a bigger or aftermarket dpfs is the material cost. If scrappers are giving 250-500 for dpf imagine how much they cost to make.
jkholder09
Jan 8, 2012
1,188
Maryland
lml has other issues, like very little fuel over 450
I had some lml charger issues as well I like the titanium aluminum turbines they spool great, put an lml on an lly and I just had to order new bering from a really nice guy today because it was way oversped and blew thrust bearings out in like 12000 miles.
I also saw the guy rev it up to like 9 lbs and immediately shut truck off so that didn't help
my point is lml turbine housing is super tight, so high flow exhaust may not be enough
its like gm designed this thing as a whole system
fyi the lly had one hell of a badass turbo brake at 100%vane zero throttle it would literally put you through the windshield
