Hello, my truck is now misfiring alot. In neutral it revs up 90% okay, but in gear driving its running maybe 50%. I can rev up to 1000rpm but any where higher it starts sputtering, knocking, and barely moving. Also the speedometer keeps dropping when it sputters!!
I have k&n filter, 4" turbo back exhaust, and a edge tuner.
I had gm hook up to the tech2, said they scanned it and i needs a ecm, but they were not sure. They said they could scan another hour to know for sure, I asked them to scan more to be certain. They called back and said it needs a injector, so i pulled the injector (it was covered/caked in black soot on one side) cleaned it and put it back, now the balance rate is down on that cylinder, but it's above +4 on 2 others. Should I change 1 or clean them all and see what the result is??? I have seen several engine codes while having this issue but deleted them....these are the current codes
U0100 lost comm with ecm/pcm
P0700 trans ctrl sys error
P0401 exhaust gas recirculation flow insuff detected
P0301 fault cylinder A-misfire detected
Could this all be because of injectors? or possibly my edge tuner? maybe both are the problem? Any help would be appreciated!!
