Here is a good one
5,950
so the samurai has the seal bearing in the distributor goin. Now i can find that bearing left and right cause its got a part number on it, problem is the seal that keeps oil out of that bearing and the cap and rotor has fallen apart as soon as i went to remove the distributor shaft and i can not find this seal anywhere online.
So, who wants a challenge?
Yes i could buy a reman dizzy but at 300 bucks, its not appealing when a bearing is 10 bucks.
And just fyi, this is a factory efi zuk. The dizzy is controlled by the computer so a carb dizzy wont work.
So here are the dimentions i need. Bore size for the seal to sit in is .793", distributor shaft size is .392" and the width of the seal is .215". All measurments were mic'ed. A .250 width seal will work but no thicker if that helps
Help me out so i aint gotta buy a reman dizzy for way too much.
