LB7: Help!!
RobsDmax
832
Arthur, Ontario
have a tune that im trying to run in my truck and it is a different os than mine, it sounds like i need to switch it to my os, but need the stock tune for that os, at least thats as far as i can read into the whole script thing. let me know thanks
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Use the Alternate Tune difference function and copy tables. Do not change operating systems unless you have a good reason to. They control more than just the engine.
RobsDmax
832
Arthur, Ontario
does that seem correct?? i load in my current dsp5 and the second one that is different os and it gives me a error message regarding the os of alt tune
RobsDmax
832
Arthur, Ontario
no i havent as it isnt a atp tune on the other truck :mad: and i have it on my other computer, it was a 013 os, cant remember what it ended in even,
RobsDmax
832
Arthur, Ontario
Ok was gonna say I have a few stock tunes and OS but not that one. Did you get your tint done?
ya ive tried to find it didnt think it would be that hard, its a 02 ecsb lb7 only gotta be a few thousand around, and nope havent yet, waiting on a scrap yard that has a set of tails so i have both sets lol
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
What OS are yo utrying to script to your current one. SInce you have an 03, I'm guessing you have an 9044. Keep in mind that not all early LB7 OS's are scaled the same as the later 02 and 03 OS's and will require some filling in and blending to make work. Let us know which 02 OS you need as I'm sure somebody here probably has it. I have a few different 01 and 02 OS's if needs be, but need to know which one.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
01337605 is os on tune im trying to get into mine, 03904405
Hate to break this to you, but that OS will never script over correctly to yours. That is a mid year 01 OS whereas yours is an 03-04. GM changed the scaling in several of teh tables mid year 02, so your going to have to smooth and blend them to make it work on several of the tables. And that OS IS here in the tune libray under the stock 2001 tune files. It is a 3376, and you would have to modify it to a DSP5 and I have found taht the script built into EFILIVE doesn't script correctly for all of the 01 OS's, so it is some work to get the stock files transferred over to all of teh DSP positions correctly.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
no problem!! guess its not gonna work anyway!!
It's doable, but takes ALOT of time. The best way to describe it is like taking an LBZ tune and putting it into an LMM. They are very simliar in how they are wrote, work with the same electreonics, but all of the tables are scaled differently, and theer is alot more of them. The early LB7's are red headed step children basically, and is why many don't use them as an 01-02 will work just as good on a 6006 02 OS as it will it's stock OS. And the 6006 is scaled just like the later 9044 to make transferring and scripting over a walk in the park. Hence why most tuners only work with the 6006 and later oS's to keep things simple and universal.
