my 2001 duramax idles up and down is a sign that fuel regulator bad and where can i get one
B bosshog99 New member Aug 11, 2010 2 0 0 Aug 12, 2010 #1 my 2001 duramax idles up and down is a sign that fuel regulator bad and where can i get one
DuraTitus New member Oct 12, 2009 32 0 0 Aug 12, 2010 #2 You need to check the actual vs. desired fuel rail pressure at idle and see if the pressure is jumping around.
