LB7: help with tune
ZeroGravity58
1,401
51
Maryland
I got my new turbo on my truck which is a 4202. I ran a 4094 before. Now below about 2100 RPM's i have no power. If you floor it off the line the truck wont smoke and the turbo wont spool. its like i only have the first 1/4 of the accelarator. After it lugs its way to right around 2100 you better hold the hell on. The fuel hits and the turbo lights and it will blow the tires right off. I cant figure out why it wont fuel below 2100. Its the same tune i was running before. Its really bad when your cruising and the TC locked. You only have the first 1/4 if the peddle. If it downshifts though it spools and takes off. If someone can help me.
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
Welcome to life with a big single. :rofl: I had a similar deal with my S475 but mines my DD so I moved to something a lot smaller. Can't help you with the tune but I know with decent tuning mine had similar response. Now with the same tuning this little S464 is a screamer :D
ZeroGravity58
1,401
51
Maryland
It's like its not getting fuel. It doesn't smoke like the turbo has lag and trying to light it just doesn't do anything.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Jonathan give me a shout , make sure the MAF is installed in the right direction in the intake ( plug pointing up ) and the MAF scaling will need to be tweaked for the 5" intake tube for it to be optimal , but Rob may have already made some of those changes for the 4094 . .
ZeroGravity58
1,401
51
Maryland
I put the 1.01 housing on the turbo it spool great and pulls its ass off after Trent helped me with a few.tuning problems :D
TrentNell
Jul 7, 2008
7,543
slc tuah
Glag those changes are working Jonathan , and glad you like the turbo setup , now quit holding out on us and lets see some pics :D , I never got to even see it installed , that stealth black and 4202 was sharp looking !!
ZeroGravity58
1,401
51
Maryland
I will get some pics of everything tomorrow :thumb:
