I have an 07.5 LMM with 5" straight pipe, DPF delete, S&B CAI, EGR blocker plate, EFI live tuning and edge for gauges. I was getting onto the highway pulling my boat and about the time I hit 70 mph I noticed a loss of power and looked back and smoke was blowing out the exhaust really badly, mostly whitish colored smoke. I pulled over and the truck was still running but idled a little lopey. I drove slow to get off the highway and it was still smoking pretty good. I didn't see any oil or coolant in the engine compartment or on the ground. After unhooking the boat I drove it a couple miles to the house and without the load driving about the 30 the smoke wasn't as bad but when I got to the house then it was still smoking and idling rough. I shut the truck off and it restarted fine. I pulled up the injector balance rates and have pics below. Do you think injectors are the problem or is it probably motor related since it happened real bad all the sudden.
Here is idle in neutral.
Here is idle in drive with the brake on.
Just wondering what else I need to check before assuming its just an injector problem.
Thanks for any responses.
