help with egr blocker
bevi
Jan 17, 2010
709
Nh
I'm trying. To put my egr blocked plate in not goin so good any tips or tricks? I have a 08 lmm
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
What's giving you problems? Should be able to back-out the 2 bolts and spread the cooler from the up pipe. Then insert the plate.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
Spray the nuts with PB blaster and try again tomorrow, there tight. I loosened the nuts and took a flat screw driver to spread the egr and uppipe apart then slid it in. It's a little tricky. Also try to get some high temp RTV on the egr side of the plate. Put the gasket on the up pipe side.
Forever
This 1 time, at band camp
Jan 4, 2009
363
Utah
The bolts are a PITA and so is prying it apart. I pried from the bottom and another person pried from the top.
bevi
Jan 17, 2010
709
Nh
ya i was just haveing trouble with the bolts brakeing loose i gave up and did my tie rod sleeve ill save the plate for another day i guess. thanks for the input guys
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
On the LMM's I cut the bottom edge of the plate at a 45 where the bolt slots are. The Egr housing itself sticks a little back further then the flange and makes it a pita to slide the plate in, if you can't spread the gap open enough.
