help with B0229
wilsonck
May 8, 2008
206
Calgary, Ab
I saw that some people on DP had gotten this code before, but no one posted here.
Just recently, I got a P0299 at the same time as this B0229 code when I was trying to get the LB7 idle with EFI. Now I can't clear the B0229 with efi. Also since I got this code, sometimes it seems as though the engine is loaded up, then I stop and go again and it seems fine. I was almost wondering if I had a problem with my SCIII.
B0229 "Recirculate Position Feedback Circuit Range/Performance" HC ($98)
"HVAC Control Module"
Any ideas? Hoping that the engine feeling loaded up doesn't have anything to do with this HVAC code...
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Dont even worry aboutthat code its something to do with the heater door flap. If you are worried I beleive you need a tech 2 to reprogram the posistion of the heater door
Someone else can probably explain it better,But ive had that code for years:D
