Just installed it. It's working.. to a certain degree. It lets me change levels, it registers boost across the LED's etc. It increases shift firmness/quickness, so I can tell it's functioning. Here is the problem: from what I can tell, it's trying to engage the TC in 1st gear! While I try to launch it.. doesn't matter how aggressive I have it turned up or down.. you start building above 5-6psi and all the sudden the truck tries to lurch forward.. will do it from a dead stop or while rolling in first with the brakes on... it did this a couple times, and I don't think it's doing the truck any good.. so I shut it off. And with it off, these issues go away and everything is back to normal...
What I'm wondering is if the VSS wire isn't working right. I soldered all connections, but maybe for some reason the co-pilot isn't getting any info from it?? would this cause it to try and lock up when it see's enough boost? ... but doesn't realize the truck isn't moving? How does the co-pilot know what gear the truck is in, or does it? The green LED for lockup on the co-pilot isn't lighting up ever either, even when the truck enters lockup under normal conditions.
Any help would be much appreciated!!!
