Help. I put the 5th in storage 3-months ago. Outlet in the bed worked fine. Go to pick the 5th up for camping and nothing works. I plug the 5th into the outlet under the bumper and works fine. Now the only thing that has happened in 3-months, is I had a drop in bedliner and took it out for a spray in type. I have power only on the battery power terminal, for the bed outlet. The fuse box under the hood is for the outlet under the bumper. I am getting power to those fuses. The fuse box by the drivers side door has no power(for the trailer) at all. I checked by removing the fuses and checking the posts. Both fuses have nothing. Is there another main fuse that supplies the main power for these that I'm missing? Help leaving tomorrow and I need this outlet to work.
