help setting a waste gate up
The Funk
May 3, 2009
220
southern indiana
Ok I have never ben around or set one up so I have no clue. I think I need a copper line running from my manfold to a t one going to the gate and another one going to a guage. Then for the other part I need one coming off of the boost side and t that one and have one side of it goinng to.the gate and the other one going to some sorta regulator. Does this sound right or not thinks for the help
MD-Dmax
Jan 6, 2010
318
yeah i would like to see how people have them pictures do more for me then people explaning it, i was talking about wastegate for twins not a single
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
the way we do them is: run a boost line to the side port of the wastegate, then at some point in that line cut a tee in. from the tee add some hose put in the regulator, on the other end of the regulator run hose to the top of the wastegate.
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
fwiw you could do the same using drive pressure instead of boost. run full drive psi to side port and regulate d/p on the top port.
MD-Dmax
Jan 6, 2010
318
do you have any pictures you could post they do more justice for me
FarmDiesel22
Farmer
Sep 28, 2009
128
I guess the pics on that site are on dodges but u can kind of the get the idea with the one pic that shows the copper line running from the wastgate down to the manifold.
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
i could get pics but it would be difficult to see, the main thing that is necessary is full boost to the side port and regulated boost to the top.
when i do mine i will use boost, i had considered using drive pressure but i didnt want to damage the diaphram in the gate from all the heat.
