Hummer (03) H2 with an 05 Duramax/Alison 6ix speed auto. 6.6 LLY. W/9000 miles
Only owned it for three weeks. Just had Predator motorsports (who did the conversion) completely go through the whole vechical, and change all fluids etc. (SYnthetics). When I drove it home I noticed that the transmission temp.s were running much higher than "normal" About 240-250 deg. When I told the owner of predator about it he said that was pretty much normal. then today while driving 70 on flat terrain. I got the "Hot transmission" message and the temps were close to 300Deg. I stopped and I had trans mission fluid dripping from the front end of the trans. pan. I checked the level while in park at idle and it was like fife inches above the hatched area marked hot. We made it home by driving 55 and it stayed hot but over 240 at that speed.... next day checked fluid level again after warming up to 125 Deg. and fluid was 2 inches above hot hatched area. trans stayed cool around town but started to heat up again as I climbed a few hills to get home..Any help??
