So I am balls deep in a water pump/thermostat job and i am also doing the 90* elbow on the oil cooler because it had been leaking for a year. I ended up figuring out what was actually leaking with help from Brian.
Now I'm trying to remove it and I was told it would come out without removing the oil cooler housing. I pulled the 2 bolts and the two nuts/studs....it now moves free but there is almost no way I can get it out without removing the up-pipe or oil cooler
Anyone messed with one of these I need help as I am completely torn apart and need my truck tomorrow for work.
