Just got done doing head gaskets, and now the truck won't start. I'e primed the system several times and my edge will see about .6-.7K PSI of fuel pressure while cranking. Any ideas?
Truck needs 1500 lbs of pressure to even open the injectors. Take the cap off the test port by alternator, prime the filter til hard. Then take a screwdriver and rag and push down on the valve inside the port. Go back to priming again, then back to the test port, repeat until no more air comes out. Prime again til hard and try cranking truck over.
was the crossover line on the driver side that feeds the passenger side rail… not quite all the way tight. Tightened it up and she cranked up quick. Thanks guys
Hey guys thanks for the help again. So I drove her all around this weekend and everything seems great. The only thing is, I'm not sure if I was supposed to lock tight the bell housing bolts.. help
