I just put head gaskets and injectors in a work truck and cant get it to start. When I try starting it the demand rail pressure is 6000 and the actual is 200-250 psi. I have worked the air out of every thing, and even put a make shift lift pump into the inlet side of the filter and still nothing. Any suggestions as to what to try next?? How do you go about trouble shooting the cp3 to see if it might be the problem? I am about ready to burn this POS!
