Back history is i got this motor from a RV with 73k had the heads decked and cleaned and new HG's and ARP Studs installed. After installing the engine i get a misfire and at times fuel knock.
I moved over the engine harness from the Kodiak RV to my Kodiak. I can upload the log file of going around the block if someone asks but we are straight out of ideas at this point.
Misfire #8
Fuel knock when at low rpm solo (Going up inclines)
2006 LBZ
ARP Headstuds
Thickness C Head Gaskets
New LDS 30% Over Injectors
PPE Race Valve
PPE Fuel Rail Fitting Supply and Return
Fass 150 Lift pump
EGR Delete
3" Y Bridge
Efi Live by Kory Willis
Heads decked .04
Grid Heater Delete
Fass Fuel Filter Delete
Engine and CP3 have 73,000 miles
Remediation Steps
1.New injector Pigtail #8
2.Swapped #8 and #3 injector
3.Verified Valve lash on #8 intake and exhaust
4.Replaced Crank Position Sensor
5.Compression test on #8 and #2 both yielded 300PSI
6.Ohm resistance test of harness at injector
7.Cleaned MAF Sensor
8.Swapped Stock ECU (Ran like shit)
This is a double post, but looking for idea's we need the truck to go to a charity event next week 1000 miles away. Just looking for idea's and help.
Misfire #8
2006 LBZ
ARP Headstuds
PPE Race Valve
Fass 150 Lift pump
EGR Delete
3" Y Bridge
Heads decked .04
Grid Heater Delete
Remediation Steps
