HELP ME PLZ!!! 04 LLY won't friggin start, fuel pump maybe?
deathmetaldiesel
Nov 13, 2011
New fuel filter on my LLY. I've primed the hell out of it and still can't get a start. It doesn't seem like i can hear the pump run when I turn the key over and when I try to start it, I get starter action. 3 weeks ago, I didn't realize I was low on fuel until my light came on and before I made it to a station, it died. I know that can put alotta strain on a pump and prolly messed it up. I put some fuel in it.. primed it and it has done fine until last night. I was rolling about 35 with just under a 1/4 tank and it just shut down. I cant get it to start and I'm pretty new to the diesel world. Should I drop the tank and change the pump? I'm mechanically capable haha I have a gnarly gasser I've built so i'm not new to mechanic work. Please... SOMEBODY HELP ME :confused::confused:
Maricopaagent
Glamis Anyone?
Oct 10, 2011
257
Arizona
No pump inn the tank... You won't hear a pump run either..
After you prime it, then crank it.. Is the fuel filter prime still hard? Might have to do it a few times...
deathmetaldiesel
Nov 13, 2011
Advance priced me for two different pumps lol must've been for a gasser. one was like a grand and the other was 300-ish. Yeah it seems to get pretty stiff when there's a good flow coming out and there's no air coming through anymore. I've cranked it for awhile and can't get nothing but starter action.
deathmetaldiesel
Nov 13, 2011
My gripe is the fact that I still have just under a quarter tank when it quit... makes it seem like a fuel pick up issue.
deathmetaldiesel
Nov 13, 2011
I definately primed it and cranked it several times. It quit with just under a 1/4 tank of fuel. Would that be a problem with a pump??
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
It could most likely be the fuel pickup tube in the tank. I have had that happen to me before. need to drop the tank and adj the pick up tube. PPE sells a high flow kit.
Maricopaagent
Glamis Anyone?
Oct 10, 2011
257
Arizona
Could be a bad pickup.. Did you add fuel to bring it above the 1/4 tank mark?
Is the primer hard after you crank it? Or do you have to reprime it?
The fuel pump on a stock truck is a cp3. Its part of the motor, not the fuel tank.
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
Duramax's have cp3 injection pumps, there is no electric fuel pump like you are thinking. I would prime it a couple times and keep trying, also there is a bleeder screw on top of the fuel filter housing that you need to crack open to let the air out off the system. You may have sucked a air pocket up by running it low on fuel.
battlegraduate09
Gearhead
Mar 18, 2010
610
o ring on the pickup in tank ? Could be sucking air at 1/4 tank. Iv never had this issue but had a 7.3 doing the same thing and this was the problem
