LLY: Help me diagnose my front end problem
paint94979
Beer Nazi
Sep 18, 2006
11,715
Driving yesterday on the 101 I felt a "thud thud" in the driverside front end? Could be the wheel bearing... there is no grinding or schrilling sound however.
paint94979
Beer Nazi
Sep 18, 2006
11,715
it almost feels like when you run over those plastic pieces that separate lanes on a HWY... my luck I sware is impecable.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Check all your stuff on that side. There's not much there. Ball joints shocks cvs. Everytime my wheel bearings have crapped they squeal
paint94979
Beer Nazi
Sep 18, 2006
11,715
Thanks Jordan, it was fine all the way back from SoCal and then yesterday it happened. Strange this is it doesn't happen all the time just sparadically(sp)
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
Maybe you ran over a squirrel.:D
Have you jacked the truck up and checked for any movement in the wheel?
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
My wheel bearing didnt squeal till the very end.
I didnt know it was bad till i thad the truck on the alignment rack, tech noticed it as he was spinning the tire/ you could see it wasnt rotating " true"
How many miles on your truck?
I hear you Cali guys have nasty freeway joints!!
wdino73
735
55
Versailles, Ky
I've had this happen sounds off base but don't hurt to check, check cab mounts and front support mounts. by driver side cab mount which is right next to your feet was bad I thought it was a ball joint sounds like it anyway, just trying to help. good luck
paint94979
Beer Nazi
Sep 18, 2006
11,715
I got $20 on a wheel bearing :thumb:
That is what I'm thinking as well Kat but I haven't put it on the lift yet... about 5,000 miles ago it had a horrible grinding sound then went away? the pass. side has a very slight schrilling sound at certain times... probably not a bad idea to just replace both.
fishsmith
1,402
42
Monroe, LA
If you have to change the wheel bearings shop around for prices. I can't remember where I got mine but there was a big difference in prices between stores.
maxaholic
1,876
40
Central, Texas
Not saying this applies to wheel bearings. But I've had plow bearings squeek and sound horrible then all of a sudden go away. Then later on you find out that it is totally trashed. And these were non servicable bearings also.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
You don't need a lift to check... Just jack up one side of the truck and grab the wheel top and bottom and try to move it ;)
paint94979
Beer Nazi
Sep 18, 2006
11,715
I should be able to investigate your front end problem in my rear view mirror at the truck in a couple months.... Ill let you know ;)
:rofl:
Why not this weekend Matt... you've got an oil leak, I have a rear axle leak and a jacked up front end. It seems fairly fair eh?
