Would like to do some head work as long as its in the budget. Would vavle springs and steel retainers from SoCal be good enough? Don't want to spend an arm and a leg yet at the same time I would like to do it right. Also after installing new springs what is needed to be done to the heads? Can you check clearances yourself or is this something for a trained person to do?
Thanks
Thanks
