Help fuel problems
dirtyduramax05
4 doors for more whores
Nov 23, 2013
66
myrtle beach sc
Ok so I started truck and it drove fine last night woke started this morning and ran fine pulled out of drive way and it started kind jumping then it would clear up a lil bit but never cleared out shut truck off started it again and it was worse did not want to idle or move didn't even make it home had to get pulled home by a dodge got home and it idled fine but would act up if u tried to give it fuel now it's back to not even idling as soon as u start it up it jumps for a second then dies I'm hoping maybe bad fuel. The check engin light came on used v2 to get code and all it said was EPA pending and gave no new numbers need help what could it be
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
Clogged fuel filters? You need to try and read the codes again. Hook the v2 up to your laptop and open the scan tool and try reading them on the laptop.
WI Huck
Where does the time go?
Feb 8, 2012
137
It doesn’t matter how long ago you installed a new fuel filter, if you got a bad batch of fuel the filter will do its job and catch the contamination. Start there. If it starts and runs decent until you give it a lot of throttle then it may be your fuel pressure relief valve on the driver’s side fuel rail.
dirtyduramax05
Nov 23, 2013
66
myrtle beach sc
I'm going to pick up new filters and drain the fuel and put fresh fuel back in but I have a ppe race fuel valve
