Yes, you are right Dale, I started having this trouble before I removed the valve body. I only removed the valve body to go through the trouble shooting steps provided by ALLDATA. I will certainly check the wiring. I checked the plugs when I bypassed the co-pilot wiring and did not find any bent pins, but will recheck.
Thanks Dale.
Meaningless OT input here.... but good luck! Not much worse than trying to fix an issue on a creeper under the truck.
