help even the dealer is stumped
riddled
Jan 26, 2016
Manitoba Canada
2012 gmc Sierra 2500 Denali
Codes p0192 p2463 p2459
Recent repairs
Under extended service
Injector in Def system
Def tanks and heaters
These repairs have cleared the codes now
Symptoms
Running rough. Loud knocking at higher rpm. Now it's giving no codes and running even worse.. dealer mechanic says it sounds like like a piston knock. Changed fuel and filter. All oil changes ate up to date. Recently had a low coolant which was low with no leaks and I topped it up. Any insight into this mystery would be great. Before the dealer start ripping motor apart which may or may not be covered under power train
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
They shouldn't just start "ripping apart the motor".
Make them diagnose it.
Have they performed any diagnostics on the fuel system other then a new filter?
Compression test?
You said it's leaking coolant but no external leaks. Have they pressurized the system and checked for leaks? Perhaps the egr cooler is leaking coolant internally...... Could be heard gaskets but I've never seen them cause a motor to start knocking or run rough.
Personally my bet is on the fuel system. Probably another cp4 pump going bad and sending debris into the injectors.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Compression test?
This ^^^^ My guess is fuel system as well.
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
Dealers don't always have the most experienced & knowledgeable diesel mechanics, but you are probably stuck with them since it's extended warranty work. I would agree with the others, probably fuel system related. I've seen diesels sound like they are knocking themselves apart due to a simple injector harness issue. Don't let them "shotgun" a solution, they've already "fixed" it once.....
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,229
372
At Da Beach
Have them drop the tank and look for metal shavings in the bottom. Is the cp4 making commanded pressure? To be honest, I'd go find a dealer who has a capable mechanic, not all techs are created equally...
Gil714
Nov 19, 2014
19
You need to check the provisions of your extended service contract agreement in terms of getting your repairs authorized by a Certified Mechanic verses a GM dealership. It wouldn't hurt to call the extended service contract company to see, based on your concerns, to see if you can use the service contract elsewhere.
riddled
Jan 26, 2016
Manitoba Canada
Talked to the tech this morning he had already started to see if he can find a problem in the injectors... should know hopefully within the hour
riddled
Jan 26, 2016
Manitoba Canada
Well now with the warmer weather and no issues... it runs fine... they think it may be the pump but all symptoms have stopped for now.. they were talking replacing the while fuel system. But now they are not sure cause it seems to have corrected with no work. Any suggestions would love to hear it.. we did go from -30 to -2
carl.swoyer
Jan 31, 2016
90
I had the #2 and#7 injectors short out sounded like a hard knocking replaced both and the knock want away
Sent from my XT1254 using Tapatalk
