hey guys. i am trying to fix my tow haul/ manual shift option on my lbz. i found that the wires were broken so i resoldered them awhile ago and heat shrunk them and everything worked fine. so today i went to use the manual shift option and it does not work again. so i get home and take it apart again and find the black wires rubbed through again and appears to have shorted the tcm or bcm on the metal part under the column, no blown fuses anywhere. where should i go from here? a potentail buyer is coming tomorrow and i would like for this to be fixed! thanks alex
