Help! Double din problem!
elliottw
396
13
ND
Hey guys I'm putting a pioneer avh 4600bt double din in my lly and can't figure out what's going on..right when I got it wired up and put it in and it worked perfectly and all of a sudden quit about 10 seconds later.
The install harness I used is a PAC c2r-gm24. All the wiring is good and I'm thinking it's the little chime box thing. It's getting power to it but it's not doing anything anymore.
I've read online that you have to add a jumper ground to ground out the harness and a lot of other stuff but none of it was silverado specific. Anybody have any ideas?
02greysixer
1,829
North Central FL
I'm not sure what interior you have but on my lly work truck model I just ran a new key on 12v power wire from inside fuse box to radio. Bypassed the chime all together. No more seat belt chime or key in ignition chime. All I lost was the key off radio on till you open a door feature. I know it won't work on a Bose system though
Sent from my SAMSUNG-SGH-I337 using Tapatalk
elliottw
396
13
ND
Im gonna do the same thing just to see if its this PAC box thats broken. What fuse did you tap?
