Am I doing something wrong? I cannot for the life of me get the cam out of the block. The whole block is empty except the cam, I have the two retainer bolts behind the gear out. It has the two piece cam gear and I took the tension off by putting a bolt through the front into the back gear. Still won't budge. Am I missing something? I don't have a service manual for the motor because it's newer than mine.
So nothing is left out, I bought the engine with a rod knock. Tore it apart and found a rod bearing that is basically worn to the point it is gone. All the main bearings are scarred. The cam turns but feels like it has some scarring in the bearings too. All the pushrods were bent and it looks like it started to shear the cam pin off. Not sure which came first. I don't think this is keeping it from coming out, but I want to make sure I give the whole scenario.
Thanks for the help in advance, I've lurked and used the forum for information for a long time. This is the first time I've not been able to find my answers through search.
