i have the same problem it could be just the 2 bolt on the front case causing the problem you can fix it by pullin the trans and converter and placing copper washers on the bolts that g around the front case ..but you could also have a cracked torque converter in that case you need to get it checked by someone that can high pressure test it .or you could buy a new converter and do the copper washers to.....
