Pulled the truck up in the driveway to load trash then shut it off to go inside to eat lunch. Come back out 30 minutes later to leave for the dump and it turns over and over but won’t fire up. Sprayed brake cleaner in the throttle body and it fired up momentarily. Noticed the fuel pump isn’t running at key on. Checked the pump fuse and swapped relays with no change. No CEL or codes.
I know the FSCM was a problem on pre 2016 trucks, especially 1500s but can’t find much info about the 2015+ 2500 gassers so I’m wondering if they changed the fuel system electronics. Anybody have experience with this or have any resources I can check out?
