help!! 06 lbz p0700 andp0735
A. Stock Lbz
Aug 13, 2013
342
spokane wa
Hey guys. Im up campin and I pulled my trailer here fine no problems, no flared shifts did as it usually does. Got here dropped the trailer parked the truck. My buddy jumps in it to go get his dirtbike that broke down and said it shifted funny and kicked the engine light on and was stuck in limp mode, wont go into reverse and after resetting the code it will go into gear fine and shift into second and then flair third and all the shifts to fifth and then go in limp mode. Trans has a ppe stage 4 and a ml-g converter. Codes were pulled with my autocal and they are p0700 and p0735 and the trans build has less than 5,000 miles. Any suggestions I can do to get the truck and trailer back to town. Thanks Alex
A. Stock Lbz
Aug 13, 2013
342
spokane wa
Holton at alligator built it. It has been flawless until now and alligator isnt open so I cant ask them any questions. Autocal will reset it but will limp again rite after
15,681
I suspect transfer case problem. You will need a professional scanner and monitor the output speed sensor.
A. Stock Lbz
Aug 13, 2013
342
spokane wa
Mike L is there anything I can do to try and reset this or anything on the transfer case I can check to get my trailor and family home tomorrow?
