hello im new to.this forum
daughertyja
Jul 20, 2012
14
Hi guys. Im new to this forum but got a question. I got acode p00087 and have changed my fuel.filter. just trying to.see what i need to do. Just hoping i dont need to change injectors
daughertyja
Jul 20, 2012
14
It has been chiped. Dont know what tuner it is.im guessing its a 100hp tune. I have changed the filter. And ran great. It seeems that it throwes the code when it has been running for awhile and is hot out. I let the truck sit for a couple hrs after i cleared the code and it runs great.but like today on the interstate i fliped a bitch and got on it and it than it threw the code
daughertyja
Jul 20, 2012
14
Im just guessing. About the tune. The guy i got it frome said it was tuned and someone broke into the truck and stole the tuner.
daughertyja
Jul 20, 2012
14
Nothing that i can see. Everything looks.dry. i wanna say it bad fuel. But dont.wanna just change.filters and that.not be the prob. They get spendy afer a couple of them
07bluelbz
Work Hard & Play Harder
Sep 6, 2009
742
Beaumont,Texas
I've popped that code twice due to bad fuel from the same station. Truck would run like crap until I burned through that tank. I quit using that station and no more problems. Put some additive in it and fill up somewhere else and see if the problem remains.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
You probably should think about having the dealer set it back to stock and see if that cures the problem, then buy a programer or EFI so you'll know what you have for tuning. Not knowing what level of tuning you have and if you dont have guages you could hurt something towing.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I would recomend a lift pump if your going to run a tuner if your cp3 is good with a lift pump you shouldnt need to change the cp3 for a very long time and if you go efi live you would need 1 anyways if you do a hot tune.
