Long story short, truck pushed coolant twice over the summer. Couldn't get it to do it again so I ignored it. Recently swapped the gt5541r on in place of my borg 98mm and now if I go WOT for an extended period of time, it will spit coolant almost every time. Truck is making 85psi boost. Currently running standard arp studs and the "wave lock" Victor reinz gaskets.
Have people prevented this by simply switching to the 625+ studs? Or is oringing it the way to go? I was trying to prevent having to do orings. Unless they can reliably be done in the heads and not the block.
Have people had issues running the 625+ studs and cracking heads?
Idealy I'd like to just do 625 studs, new gaskets and be done with it, but i dont think it's going to be that simple. Unless others had good luck that way.
