Headlight replacement
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Anyone have any experience with these type of headlight? No cheap halo. Just a low beam projector and regular high beam in a black housing. Or does anyone have a better option with a black housing? These are the only ones I found that look to accept an led bulb
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
You can use retrofit source for parts, I agree that if you want projectors you should either have an experienced fitter or do some research and do them yourself, TAKE YOUR SWEET TIME for if they leak moisture you will wish you had! However retrofit source has some adapters that will twist into the lens side of the bulb socket once you have removed the lens, no cutting for the easier of kits and the same clean beam edges and look.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Okay so I pulled the plug on these because I'm a stubborn mule and I am extremely impressed. The quality of the housings are phenomenal. Heavy and solid to say the least. Put my morimoto led bulbs in and WOW HOLY BRIGHT. First pic is low beam. Second is low and high. No fog lights on.
