Tyler this is Larrys headcount thread. :thumb:
F it
fml...
:rofl: Ill do my best the way it is then. A low 13 sec pass in street trim would be awesome
Im a little confused what you disagree with me about?
You prefer IFS over SFA?
You think the Allison can handle more power than the 6.4's trans can?
Personally im impressed with what the ford guys are doin with the 6.4. I mean no one here has made over 550 horses with tuning, intake, and exhaust and ran 12's consistently without breakin shit. I think they are good lookin trucks too. And that was my main point here, my truck needs some work and the new 6.4's are a nice truck.
Kinda curious what you disagree with me about
Well, if you really want to know. No, I don't think the Ford transmission is any stronger than the Allison in "stock" form. One thing you need to realize is the Ford is totally electronic. They do things with programing that we do with pump and valvebody modifications. I could pull a transmission and drop in some transgo valves, a cutback valve, and shim the pressure spring and handle just as much abuse as any Ford transmission, but what's the point? All I would be doing is buying time on the stock clutches and converter, which is exactly what they are doing. If the transmission was strong enough to survive under that kind of power, why would there be companies out there that build them and sell kits for them?:rofl: Ill do my best the way it is then. A low 13 sec pass in street trim would be awesome
:doh:
if you are thinking about switching to a ford because of one problem (trans), you might as well just stop racing. and wait until you get a repair bill on a ford...
p.s. i'm not helping you work on a ford.
No, I don't like solid axles either. The only axles that are stronger than an IFS are the old kingpin Dana 60s that don't use ball joints and have real spindles with serviceable bearings. The solid axles that are used in trucks today have the same stupid unit-bearing hub that our IFS has and they use ball joints at the knuckles that cause just as much trouble as ours. Not to mention that they suck to drive. Not just the ride, but the way they track down the road. Track bar problems are the norm. You either work on it all the time or you live with a truck that sucks to drive. If you don't like the IFS that's in your truck, why not spend money to upgrade it rather than wasting money on 100 year old technology. I don't buy the "solid axle is stronger offroad" argument either. Look at what type of suspension is in the front (and often even the rear) of most desert racing trucks and buggies. I bet you can count on one hand how many of them have a solid front axle. The only ones that do probably run in a class that requires stock style suspension. Do you think anything you do is harder on a suspension than that? I'll keep my IFS, thanks.
I won't disagree with the kind of power the 6.4 is capable of. I think it's nice they finally got a motor that you don't have to throw gobs of money at to get over 450 HP.
Honestly, I'm not sure how much you can do to beef up the front end without spending several thousand on custom parts. I think it would be really sweet to build a fabricated front end with long arm suspension and custom knuckles that have real spindles and hubs, coilovers instead of torsion bars, and some beefed up CV axles.Im gonna replace my front end and put in as many beefed up parts possible and see how I like my IFS....Any upgrades youd reccomend other than idler pitman arm support and stronger tie rods?
And if my front end is saggin what parts are goin out or is it just the weight of my big bumper. Somethin is defintely wrong though cause when I had my tbars Maxed out it looked like they weren't even turned up.
