ok guys i changed out my head gaskets today along with two injectors and now the truck starts but its only running on 4 cylinders. im getting codes p0201 p0204 p0206 p0207 and p2146. i can guarantee all the leads are hooked up to the injectors under u valve cover and i went through the bale connectors and pulled all the pins to make sure that wasnt the problem. i checked all the connections and they look good and secure. also i have no reading of oil pressure on the gauge, funny thing is the display doesnt say "check gauges".
also i have 2 connectors that have no home. 1 is the yellow multi connector that is next to the bale connectors with about 3-4 inches of reach it looks exactly like the glow plug connector but that plug is connected and the the reach is no where close and i have no idea where its supposed to go. the other looks like a ground terminal and i checked it with a test light and it has no power. its not the glow plug connector or the ground its too small to fit onto any of the firewall ground connections and i have no idea where it goes.
any help will be much apperciated fells my truck is stranded and my family is hurtiing till i get this figured out.
here is a picture of the plug and wire.
