Anyone have the steps for lifting the cab to do a headgasket on a lbz crew cab?
Also whats the part number for the head dowels that go into the block
Thanks
That's crazy, we can pull the motor in less than 2 hours. You've got a good point about the the AC, we have a machine so I don't think much of having to recharge it.
So do you have the steps of what u gotta pull to pull the motor and steps for pulling the cab? Pulling the cab i was woundering what u disconnect on the brakes also where do u lift it at
Some pull the motor others pull motor and some leave in, i m just tryin to figire out which way is the best, any input is welcome, really looking for a step by step or list of what all is involved
If your just doing gaskets I'd pull the cab. It take 2-3 hrs. then there's no need to remove converter bolts and with the motor still all bolted up its a lot easier to torque the heads. Brakes wise just undo the master cylinder from the hydro boost. Then there's no need for bleeding brakes after. Lift the cab by the pinch welds.
I pull the engine. Don't have a lift to pull the cab or I might try it just to see. But OP I would say you unbolt the hydrobpost unit and master cylinder as one piece and leave it with the frame.
