Posted this on DP also
Long story that started last summer...
Last summer I noticed a small leak from I think my water pump then it began puking coolant out the resevoir and my upper rad hose stayed hard over night and I got frequent low coolant warnings. After some research I was convinced I had a blown head gasket. People told me I was crazy so I tried bleeding the system and topped the coolant up.
All was great! The leak seemed to go away Never got another low coolant warning and everything was back to normal.
Now 6 or 7 months later and about 15K miles its happening again. I cant keep coolant in the thing...pukes it all up. The engine doesnt warm up forever and then suddenly will be overheating then go back to cold. The upper rad hose is hard over night and the overflow has bubbles sometimes. I tried bleeding the system but its only temporary then pukes a bunch of coolant back out. I have no loss in performance and just did an oil change yesterday. The oil seemed to be normal...no milky colouring.
Im wondering If I MAYBE just have bad T-stats and water pump and there is air trapped in the system that I cant get out??? It pukes coolant mostly after the truck is shut off.
I ordered t-stats and water pump today so Im gonna start there.
Any input would be greatly appreciated.
