Head gasket
wes06dmax
Feb 23, 2009
1,367
South Central Kentucky
Compression Test the cylinders and usally if you have a headgasket leak the engine will shake like hell because your compression is all of wack were it is leaking compression into the next cylinder
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Its tough to tell , because of the injector cups , they both have very similar if not identical symptoms , If you pull it down , pull the injectors out of the head before you pull the heads off and if all the cups stay in there place and show no signs of lifting then its likely you head gaskets .
wikdlmm
<-- OWFA
Jun 27, 2008
1,974
san angelo
It's the lb7, so should I do a compression test first Trent or pull the heads? We just keep getting water i'n the oil....Also when we roll out of the burnout on the slicks it white smokes pretty good thelears up if that has anything to do with it.
