Hi folks!
First couple posts here and I'm a bit new to diesel engines. I'm pulling the block on my father in-laws '04 GMC 6.6 Duramax to replace the head gaskets and do any other basic stock upgrades that should be done at the same time. The truck has all the symptoms of a blown head gasket leaking compression gasses into the coolant system and I've also checked and verified with one of the liquid coolant/gas testers. Blue --->Green.
I keep reading about the ARP stud upgrade from stock head bolts and have a question about torque plate honing. I understand this is a step you might want to take with a new build/bare block, but is it necessary/required for just a basic HG job on a motor with 108K miles on it? This motor is not tuned, boosted, nothing...bone stock. It gets mild use most of the time, and twice yearly hauls a 32' 5th wheel trailer about 2500 miles and the driver does NOT have a heavy foot.
The lower end of this engine is still in great shape and I don't plan on pulling the pan unless I find some reason after the block is out.
I do plan on replacing the water pump at the same time just for good measure. Is there anything else I should consider while the block is out?
Thanks for any advice. ARP Studs, Water Pump. Injectors? Glow Plugs? Oil Cooler? Oil Pump?
Jim
Jim
